Parental controls RT-AC68U
empl0de
Just a quick question, what does parental controls block? Just web traffic? As I am able to use Netflix app when parental controls are active.
Just using Stock firmware 378_4585
Try it and find out. It should block web traffic that isn't an active TCP connection. The limitation is it doesn't disconnect and only blocks. Eg: Active Youtube stream will continue to work on the denied time. The user has to close the page/connection for it to block future requests.
