Hi everyone,
I recently bought a 8TB to replace my 4TB backup/media drive which is attached to my RT-AC56U router running Asuswrt-Merlin.
Disk was probably formatted NTFS out of the box, so (as recommended by many) I SSHed to my router and formatted it to ext4 (using mke2fs -t ext4).
Everything seems to be good, except that the drive now shows up mounted as sda2 and not as sda1 like my old drive used to (not tragic, but somewhat inconvenient because it means I'd have to relink/rescan links and databases referring to content on the drive, including Kodi).
So I started looking into ways to change the disk level (which seems easist). Here's where I ran into problems...
So I missed that Microsoft reserved partition - meh.
Seems like I'm having some problems here which I need to fix. Not sure, however, if I fully understand what's going on. Does anyone have more insight?
I guess I can get this ironed out by hooking up the machine to my windows computer and formating it from scratch with Partition Manager (get rid of the MS partition, use GPT instead of MBR for the partition table and relabel it), but I'm not exactly looking forward to moving over 4TB of data to the disk yet again, so if there's an easier path, I'd really be happy.
Thanks a bunch!
# fdisk -l
Disk /dev/mtdblock0: 0 MB, 524288 bytes
255 heads, 63 sectors/track, 0 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Disk /dev/mtdblock0 doesn't contain a valid partition table
Disk /dev/mtdblock1: 1 MB, 1572864 bytes
Disk /dev/mtdblock1 doesn't contain a valid partition table
Disk /dev/mtdblock2: 65 MB, 65011712 bytes
255 heads, 63 sectors/track, 7 cylinders
Disk /dev/mtdblock2 doesn't contain a valid partition table
Disk /dev/mtdblock3: 63 MB, 63316992 bytes
Disk /dev/mtdblock3 doesn't contain a valid partition table
Disk /dev/mtdblock4: 65 MB, 65798144 bytes
Disk /dev/mtdblock4 doesn't contain a valid partition table
Disk /dev/mtdblock5: 1 MB, 1310720 bytes
Disk /dev/mtdblock5 doesn't contain a valid partition table
fdisk: device has more than 2^32 sectors, can't use all of them
Found valid GPT with protective MBR; using GPT
Disk /dev/sda: 4294967295 sectors, 2047G
Logical sector size: 512
Disk identifier (GUID): 9240905d-56d0-4428-971f-1cc8f15f94c0
Partition table holds up to 128 entries
First usable sector is 34, last usable sector is 15628053133
Number Start (sector) End (sector) Size Code Name
1 34 262177 128M 0700 Microsoft reserved partition
2 264192 15628052479 7451G 0700 Basic data partition
Thanks a bunch!
