Paste this code, does it look ok
Jack-Sparr0w
Debug date : 2024-07-19 02:39:31-0500
Router Model : RT-AC66U_B1
Firmware Ver : 386.13_0
DPI/Sig Ver : 2.0.1 / 2.412
WAN iface : eth0
tc WAN iface : eth0
IPv6 : disabled
Undf Prio : 2
Down Band : 66560
Up Band : 66560
Net Control : 1:10
Work-From-Home : 1:13
Gaming : 1:11
Others : 1:16
Web Surfing : 1:14
Streaming : 1:12
File Transfers : 1:15
Learn-From-Home : 1:17
Downrates : 3328, 9984, 19968, 13312, 6656, 3328, 6656, 3328
Downceils : 66560, 66560, 66560, 66560, 66560, 66560, 66560, 66560
Uprates : 3328, 9984, 6656, 13312, 6656, 3328, 19968, 3328
Upceils : 66560, 66560, 66560, 66560, 66560, 66560, 66560, 66560
iptables settings: Defaults
-A FlexQoS_down -p udp -m multiport --sports 500,4500 -j MARK --set-mark 0x8006ffff/0xc03fffff
-A FlexQoS_up -p udp -m multiport --dports 500,4500 -j MARK --set-mark 0x4006ffff/0xc03fffff
-A FlexQoS_down -p udp -m multiport --dports 16384:16415 -j MARK --set-mark 0x8006ffff/0xc03fffff
-A FlexQoS_up -p udp -m multiport --sports 16384:16415 -j MARK --set-mark 0x4006ffff/0xc03fffff
-A FlexQoS_down -p tcp -m multiport --sports 119,563 -j MARK --set-mark 0x8003ffff/0xc03fffff
-A FlexQoS_up -p tcp -m multiport --dports 119,563 -j MARK --set-mark 0x4003ffff/0xc03fffff
-A FlexQoS_down -p tcp -m multiport --sports 80,443 -m mark --mark 0x80080000/0xc03f0000 -j MARK --set-mark 0x8003ffff/0xc03fffff
-A FlexQoS_up -p tcp -m multiport --dports 80,443 -m mark --mark 0x40080000/0xc03f0000 -j MARK --set-mark 0x4003ffff/0xc03fffff
appdb rules: Defaults
filter change dev br0 prio 2 protocol all handle 828::800 u32 flowid 1:16
filter change dev eth0 prio 2 protocol all handle 828::800 u32 flowid 1:16
filter add dev br0 protocol all prio 2 u32 match mark 0x8000006B 0xc03fffff flowid 1:16
filter add dev eth0 protocol all prio 2 u32 match mark 0x4000006B 0xc03fffff flowid 1:16
filter add dev br0 protocol all prio 15 u32 match mark 0x800D0007 0xc03fffff flowid 1:15
filter add dev eth0 protocol all prio 15 u32 match mark 0x400D0007 0xc03fffff flowid 1:15
filter add dev br0 protocol all prio 15 u32 match mark 0x800D0086 0xc03fffff flowid 1:15
filter add dev eth0 protocol all prio 15 u32 match mark 0x400D0086 0xc03fffff flowid 1:15
filter add dev br0 protocol all prio 15 u32 match mark 0x800D00A0 0xc03fffff flowid 1:15
filter add dev eth0 protocol all prio 15 u32 match mark 0x400D00A0 0xc03fffff flowid 1:15
filter add dev br0 protocol all prio 20 u32 match mark 0x8012003F 0xc03fffff flowid 1:14
filter add dev eth0 protocol all prio 20 u32 match mark 0x4012003F 0xc03fffff flowid 1:14
filter change dev br0 prio 22 protocol all handle 802::800 u32 flowid 1:14
filter change dev eth0 prio 22 protocol all handle 802::800 u32 flowid 1:14
filter change dev br0 prio 23 protocol all handle 804::800 u32 flowid 1:14
filter change dev eth0 prio 23 protocol all handle 804::800 u32 flowid 1:14
class change dev br0 parent 1:1 classid 1:10 htb overhead 18 linklayer ethernet prio 0 rate 3328Kbit ceil 66560Kbit burst 8320b cburst 83200b quantum 41600
class change dev eth0 parent 1:1 classid 1:10 htb overhead 18 linklayer ethernet prio 0 rate 3328Kbit ceil 66560Kbit burst 8320b cburst 83200b quantum 41600
class change dev br0 parent 1:1 classid 1:11 htb overhead 18 linklayer ethernet prio 1 rate 9984Kbit ceil 66560Kbit burst 8320b cburst 83200b quantum 124800
class change dev eth0 parent 1:1 classid 1:11 htb overhead 18 linklayer ethernet prio 1 rate 9984Kbit ceil 66560Kbit burst 8320b cburst 83200b quantum 124800
class change dev br0 parent 1:1 classid 1:12 htb overhead 18 linklayer ethernet prio 2 rate 19968Kbit ceil 66560Kbit burst 8320b cburst 83200b quantum 249600
class change dev eth0 parent 1:1 classid 1:12 htb overhead 18 linklayer ethernet prio 2 rate 6656Kbit ceil 66560Kbit burst 8320b cburst 83200b quantum 83200
class change dev br0 parent 1:1 classid 1:13 htb overhead 18 linklayer ethernet prio 3 rate 13312Kbit ceil 66560Kbit burst 8320b cburst 83200b quantum 166400
class change dev eth0 parent 1:1 classid 1:13 htb overhead 18 linklayer ethernet prio 3 rate 13312Kbit ceil 66560Kbit burst 8320b cburst 83200b quantum 166400
class change dev br0 parent 1:1 classid 1:14 htb overhead 18 linklayer ethernet prio 4 rate 6656Kbit ceil 66560Kbit burst 8320b cburst 83200b quantum 83200
class change dev eth0 parent 1:1 classid 1:14 htb overhead 18 linklayer ethernet prio 4 rate 6656Kbit ceil 66560Kbit burst 8320b cburst 83200b quantum 83200
class change dev br0 parent 1:1 classid 1:15 htb overhead 18 linklayer ethernet prio 5 rate 3328Kbit ceil 66560Kbit burst 8320b cburst 83200b quantum 41600
class change dev eth0 parent 1:1 classid 1:15 htb overhead 18 linklayer ethernet prio 5 rate 3328Kbit ceil 66560Kbit burst 8320b cburst 83200b quantum 41600
class change dev br0 parent 1:1 classid 1:16 htb overhead 18 linklayer ethernet prio 6 rate 6656Kbit ceil 66560Kbit burst 8320b cburst 83200b quantum 83200
class change dev eth0 parent 1:1 classid 1:16 htb overhead 18 linklayer ethernet prio 6 rate 19968Kbit ceil 66560Kbit burst 8320b cburst 83200b quantum 249600
class change dev br0 parent 1:1 classid 1:17 htb overhead 18 linklayer ethernet prio 7 rate 3328Kbit ceil 66560Kbit burst 8320b cburst 83200b quantum 41600
class change dev eth0 parent 1:1 classid 1:17 htb overhead 18 linklayer ethernet prio 7 rate 3328Kbit ceil 66560Kbit burst 8320b cburst 83200b quantum 41600
[/CODE][/SPOILER]
