I did that.You might need to reset the files via the Create or reset IPTraffic data files
Where do you have it writing the files to? And what interval?
That didnt work. Last night I formated a thumb drive as ext2, connected it and pointed it at that. No results this morning.I believe you need to set it to either USB or NVRAM for that to work for the Per IP monitoring - I'd suggest USB formatted EXT2.
ls dash l /mnt/SD/RTN66ULogs/
-rw-rw-rw- 1 admin root 20 Feb 19 11:53 tomato_cstats_08606eeab900.gz
-rw-rw-rw- 1 admin root 40 Feb 19 11:53 tomato_rstats_08606eeab900.gz
/mnt/SD/RTN66ULogs/
traffic is the name of the thumb drive.Doesn't look like your mount point is correct unless traffic is what you assigned as the name of the thumb drive. Did you manually type in the entry or did you use the select and browse to the folder?
The folder should have two entries one like the following:
Code:ls dash l /mnt/SD/RTN66ULogs/ -rw-rw-rw- 1 admin root 20 Feb 19 11:53 tomato_cstats_08606eeab900.gz -rw-rw-rw- 1 admin root 40 Feb 19 11:53 tomato_rstats_08606eeab900.gz
In my test case I've got the stats being saved to the SD card.
Code:/mnt/SD/RTN66ULogs/
Welcome To SNBForums
