Per ip rate limit
tommyhaha
Hello buddies,
I got an AC68U router with Merlin system, do you know how can I rate limit per ip? I got roughly 100 user son site, all within 10.0.0.024 subnet
You can successfully service 100 simultaneous clients on an AC68U?? I had trouble with 30 (CPU overload) last time I checked about 6 mos ago.
Actually Im just using the PPPoE/routing/VPN function in AC68U, but using Cisco WLC +AP as the wireless connection.
Ah ok, yes not using the wifi does take a load off the main cpu. I know these separate wifi chips are supposed to handle everything but feeding the drivers does put some strain on the main cpu.
Sent from my SM-N910V using Tapatalk
100 users is too many for the cpu on an AC68, especially if you use advanced features like QoS. That said, you might be able to eek out something provided the desired bandwidth is low and a bit laggy.
Sent from my SM-N920V using Tapatalk
