Shikami
pfSense store has a interesting router, it may seem. As some are becoming more fancy with networking and needing a vast range of networking abilities for home, I was curious if it was possible to review the VK-T240E?: https://www.pfsense.org/hardware/pfsense-store.html#vkt40e
Hardware Specifications
Case Desktop case with Ethernet, USB and antenna cutouts
Cooling Fanless / Passive
Power External 100~240 VAC In and 12 VDC, 2A, 24W Out Power Supply
Dimensions 6.61" (168mm) x 6.18" (157mm) x 1.18" (30mm)
CPU 1 GHz Dual Core AMD G-T40E APU
Memory 2GB or 4GB DDR3 1066 DRAM
Hardware Warranty 12 Months
Interfaces 3x Realtek Gigabit Ethernet ports
Certifications CE, FCC, RoHS, UL
Storage 1x SanDisk 8GB SDHC Card
Console Port Serial
Power Consumption 11W (idle)
USB Ports 2
Console Port Serial
USB Ports 2
