drummer914
When it happens I can still ping everything connected to the node just fine from behind the master AP. Everything on the node still has internet. But, for some reason the Hue app will connect via WAN instead of LAN, which still works, but the Sonos speakers disappear from the app (besides the one connected behind master AP). Maybe UPnP mesh issue? The Sonos speakers and Hue bridge are connected to the node via ethernet.
I have an AC3100 in AP mode running 384.13. The mesh node is an AC68P running stock firmware v. 3.0.0.4.384_45717-gadd52a8. Both were reset to factory defaults when I set up the mesh network, and the only settings I changed from default is the login, network name, and password. Signal strength pretty darn good between the two.
