Hello community today i'm encountering an issue that i can't root out. My set up is as follow, 86U with asus merlin and 4 nordvpn client running. Pihole with unbound.
The way i have it set up is as follows:
WAN DNS is using cloudfare
LAN DNS is using PIHOLE IP
DNS DIRECTOR is ON with global redirection set to no redirection and RPI where the pihole is running is set to no redirection
I'm using domain vpn routing script to create a tunnel for specfic domains, mainly NETFLIX, DISNEY, AMAZON, MAX. Each VPN client configuration has a country region and each has its DNS set to Exclusive.
When i do i simple test of going to DNSLEAK or IPLEAK i end up with my ISP IP AND DNS even though i have added all their domains to the vpn routing script. i'm at loss to be honest any help would be appreciated
