Rango
PIA AES-256-CBC with OpenVPN is out but not working on Asus routers. Any idea what i need to do to have this working? They have some kind of patch but this asus is router i can not install unless it's vnram command?
It fails with error or authentication failure and i checked my username and password. I did not apply any patch as it's a router not a windows client unless in custom config, some line?
Cert was copied to CA field. Changed port to 1197, using midwest server.
Any ideas? Maybe there needs to be custom configuration settings added.
I tried few configs but none work. Currently using. It might be the case that something in custom config needs to be enabled, or maybe new ovpn file needs to be crated or modified. Not sure.
Customer config line:
tls-client
remote-cert-tls server
reneg-sec 0
Few threads for info and patch?
https://www.privateinternetaccess.c...stock-openvpn-with-strong-encryption-settings
https://www.privateinternetaccess.com/forum/discussion/9093/pia-openvpn-client-encryption-patch/p1
Thank you very much for help
tls-client
reneg-sec 0
