Hi.... newbie here. Thank you to Merlin and the members here for an outstanding build.
I have an RT-AC68U with 378.56.2 Asuswrt-Merlin. I have a home network, in Canada, with about 15 devices (from time to time). I need to defeat geo-blocks from Netflix, NHL and Hulu.
My OpenVPN client is properly installed. I set up Client Instance 1 as PIA in NYC. It is functioning properly with a Status - connected.
I also set up Client Instance 2 as PIA in France. It is installed in the same manner as Instance 1. However, if I put it on (or select it at startup), I get a message of "conflict". For now, I have stopped Instance 2. How can I ensure that the 2 instances co-exist without issue?
Also, I am still unclear (even after exhaustive reading here) of how Policy rules are applied. Here is the example:
On Android Box A, I want to use PIA-France tunnel only on Netflix. All other traffic from this box should go through PIA-NYC tunnel. I'm lost on how to set this in the Policy UI.
Thanks for any help which you can give to me.
