First of all thanks very much to ASUS tech support which try to help me to solve the problem in the past few months
I had a ping lost problem when I reboot the main/node, I have this problem a long time and today ASUS support said they still can't find the reason, so I am here to see if someone can reproduce my problem.
I use my AC68u as AP, with 2 more AC68U as node, they are using ethernet as backhaul, when I reboot the main/node, doesn't matter only one of them or all of them, my PC which is not connect to any AC68U will have ping lost, the more the node reboot, the longer and easier the ping lost happen.
As it seems this is a rare case and ASUS told me they can only reproduce this problem once
If you have time please do me a favor to have a test, make sure you have flow control turn on, as with flow control turn off there will not have any ping lost:
1. keeps ping www.google.com
2. keeps ping the all asus router(both the main and the node)
3. telnet into the node and reboot them
4. if you see ping lost to www.google.com before the node finish reboot, that means you have the same problem with me, normally you should not see any ping lost.
p.s. sometime it will also have ping lost if reboot the main instead of the node
I had attach my network diagram for anyone interested.
