el pescador
Downloaded the new version and decided to give the udp test a go.
Its set to every 2.5 seconds.
It works well with no packet loss on the router.
Im running 380.59 alpha 2 on the AC88U.
Had no problems so wont change till 380.6 is up and running.
But when i change the send frequency on pingplotter to .5 seconds i get high packet loss on the router.
Any one have a clue as to why?
if game are using udp at a frequent rate surely this will cause an issue??
