pixelated image movistar tv
chiquito
You will see I have a gigabyte network card pc a nas synology and a router rt-ac88u and a tv receiver for movistar tv. when I am passing files to synology, the image is pixelated ... as long as the transfer speed exceeds 110mg per second as long as this speed does not pass, nothing happens and when the transfer ends, everything remains the same without problems ..
You know that you can be?
Have you tried enabling igmp snooping on the LAN>IPTV settings. Helped me.
Hi, I have had the same problem. My solution after much fiddling has been to limit max bandwidth of the cabled devices to a max of 100mb/s transfer speed... I could not solve this problem with any other form of QoS.
I yesterday after many tests I put the rj45 cable in the mouth of router number 3 and to date it is not pixelated and I transfer to 110-113 mgs.
