POLL: Sub $200 ASUS router models with AiProtecion
Best ASUS router model under $200
  • RT-ACRH13
    Votes: 0 0.0%
  • RT-AC66U/R/W
    Votes: 0 0.0%
  • RT-AC66U B1
    Votes: 1 8.3%
  • RT-AC68U/R/W/P
    Votes: 7 58.3%
  • RT-AC87U/R
    Votes: 0 0.0%
  • RT-AC3200
    Votes: 0 0.0%
  • RT-AC86U
    Votes: 4 33.3%
  • Total voters
    12
L0nkFromPA
Let me start by saying that I understand that requesting people's opinions is going to result in biased answers, etc and there are pros and cons for every router model / architecture, etc.
My issue is that in years past, there seemed to be far fewer choices when it came to wireless routers with open source firmware support. Some models that I can think of that were well supported by various firmware projects were the RT-N16, RT-N66U, RT-AC66U. These are all MIPS R2 routers. Before AsusWRT, open source support seemed more important to actually get a decent firmware. Now that they've based it on the Tomato firmware, I am less concerned about that.
So, this is the basis of my poll; what in your opinion is the current best choice in Asus router, considering price, reliability, architecture, radios, build quality, speed, range, third party firmware project support, etc.
I would like to put a particular emphasis on price, since many people don't want to pay $200+ for a router, even though in my opinion it is well worth it. I've been relatively inactive in monitoring forums and firmware development for the last several years.
I picked a few models that I consider to be good candidates below, but if you feel I'm off track, you can also pick a model not listed. In the models that I've chosen, I've only included routers with AiProtection and external antennas, since I consider these to be important features.
The models are in order of ascending price on Amazon.
I have a RT-AC66U B1 which is like the RT-AC68U. Has dual core processor and USB 2 and 3 ports. Does not have removable antennae. Runs the stock Asus firmware very well or the Merlin for the RT-AC68U. Think I spent $119 for it at New Egg.
Also have two RT-AC68U running Johns fork in a small business.
Sent from my P01M using Tapatalk
The RT-AC66U_B1 is a very good deal. The RT-AC86U is a much better device, but it will depend on what you actually need out of your router - the B1 is a good price/feature balance.
Thanks for the replies. I'm guessing the main reason why the 86U is much better is because it's clocked at 1.8? Expanding on that, at the high end, the GT-AC5300 has a quad core broadcom processor @ 1.8, as opposed to the 86U's dual core. Does this firmware actually use 4 cores effectively, or is there going to be little difference?
It's not just a higher clock, it's a new CPU generation. Kinda like comparing a Core 2 Duo with a Core i7 - there are performance improvements in the architecture itself.
