Poor Performance with Asus Blue Cave AC2600
Griffon783
Hey,
I recently purchased the asus blue cave router and configured an OpenVPN on it. I typically get about 300 Mb down/up and was expecting a performance hit, but when the VPN is activated I'm only getting 15 Mb down/up.
I know this router is far from the best, but I did expect better VPN performance than this. I know OpenVPN can only use one core of the processor and I am seeing that one of the cores is maxed out during a test.
Is there anything I can do to improve performance, or is this router just limited by it's processor?
Thanks.
Bluecave has extremely slow cpu for encryption performance.
Bluecave
type             16 bytes     64 bytes    256 bytes   1024 bytes   8192 bytes
aes-128-cbc       8263.86k     8783.15k     9962.75k    10107.56k    10076.16k
RT-N66U
aes-128 cbc      12327.56k    13300.38k    13847.73k    14002.52k    13961.90k
RT-AC56U or RT-AC68U
aes-128 cbc      44653.45k    48938.15k    50584.75k    51367.22k    51593.05k
RT-AC86U
aes-128-cbc     187611.30k   531473.32k   964847.62k  1239431.79k  1354129.33k
Hey,
Thanks.
The RT-AC86U is said to perform well for VPN.
OE
The rt-ac86u need the Merlin firmware flashed to it to enable hardware acceleration stock firmware does not have it to my understanding.
Stock firmware has hardware acceleration working.
15 Mb down/up
That is a bit surprising, but perhaps not - even the GL-AR300M (QC-Atheros 9531 MIPS24K @ 650MHz) can do 18 Mbit/Sec over OpenVPN with OpenWRT - and the AR300M is quite a bit slower chip than the Lantiq/Intel SoC in the BlueCave...
AR-300M
aes-128 cbc       7896.65k     8725.36k     8957.60k     9049.38k     9060.68k
