yetollerey
I have a problem with poor Wi-Fi speeds. I'm testing it via Speedtest.net and i'm getting 3Mb (from closed range) instead of 30Mb. If I connect my Laptop directly to the main router, i'm getting the full 30Mb.
Of course i'm testing the Wi-Fi speeds using the wireless main router, not the access point.
Let me explain my setup:
Main router: Linksys WRT1900AC
Wireless Wi-Fi access point: TP-LINK TL-WR841N.
Both devices with latest official firmware.
When I defined the Wireless Wi-Fi access point in the TP-Link, i did it using the build-in Survey option. Both devices are using channel 1, so I thought maybe that's the reason for the slow Wi-Fi. If I try to change the channel in one of the devices to other then 1, the Wi-Fi access point does not work. This is just a thought, don't sure if that is really an issue.
Anyway, would appreciate any help from the friends here
