Port forwarding broken with HW NAT acceleration
sanbop
After upgrading to 386.1_2 (from a version that was at least a year old) port forwarding (on some non-standard ports, not sure if that matters) broke, until I disabled HW NAT acceleration (i.e. set it to “Disable” from “Auto”).
The way it broke was that I could make the TCP connection (from outside my home network) to that port, but then the client would just hang there and then time out eventually. Interestingly if I did a manual test (e.g. using telnet to the same port) and then I “nudged” it - e.g. pressed enter to send something - the other side seemed to come alive (i.e. the protocol-specific version version number was returned by the service behind the ASUS router). For now I just disabled HW NAT acceleration and moved on, but I figured this might be something worth looking into (or could help others facing the same issue).
  • Router: ASUS RT-AC1900
  • Firmware: 386.1_2 (RT-AC68U firmware)
  • WAN connection: Using PPPoE
I had this same issue and can confirm Disabling HW NAT Acceleration fixes the port forwarding issue. Seems to be a bug in this newer firmware.
Edit: Adding that my Device that is having this issue is a RT-AC3100.
Same thing here on my RT-AC3100, static IP WAN. I didn't really notice the hanging until I updated from Merlin 386.2_2 to Merlin 386.2_6 though, but I had also just changed some port forwarding rules due to adding another server to the LAN to handle some services that my older NAS was handling. I just now disabled NAT Acceleration and it seems to be working much better so far.
I'd like to confirm I have the issue as well on my RT-AC3100. In my case, it's affecting standard ports (HTTP and RDP). I am concerned how turning off the NAT acceleration might affect performance since I do have a fiber connection.
Do we have any idea where the bug lies, or if Merlin is able to fix it? Or is it something he'd have to wait on Asus to fix. I'm debating whether to roll back to earlier firmware.
I ended up submitting a report on GitHub, and based on our conversation, it's a bug outside of Merlin's control. I guess we can only hope that the appropriate party can or will fix it.
Based on our conversation, he recommended installing the stock firmware and confirming the issue was there as well (it was). He then recommended using the feedback form at the bottom of the WebUI to make Asus aware of the issue. I strongly encourage everyone here to do that as well, as the more users who bring it up, the more likely they are to care.
I really don't feel like installing the stock firmware. Is it possible to post the link here to the feedback form to submit the bug report?
It's a page within the firmware.
I was still having trouble accessing my Synology Surveilance Station externally, despite NAT Accel being disabled. I would also have to reload pages often on my Nextcloud site, although it was still much better than when NAT Accel was enabled.
I tried disabling DoS Protection, and I can now connect to my surveillance station much more reliably and faster. It also sped up and increase reliability to my Nextcloud site. Maybe DoS Protection can cause issues with services that do a lot of rapid back and forth handshaking.
I did try with DoS Protection off and NAT Accel on, but that seemed as bad as it ever was, so NAT Accel is still definitely the primary issue here i think.
I'd like to post a quick update regarding this situation with my RT-AC3100. Recently my speeds started to tank when going through my router. Instead of getting ~900Mbps both ways, I was *lucky* to hit 400Mbps either way. It was typically quite a bit lower. I'm not sure exactly when it started because I'm almost always on a VPN which limits my speeds somewhat anyway.
Anyhow, after a whole bunch of troubleshooting, I said "screw it" and did a factory reset on the current Merlin 386.3 firmware. My speeds were then exactly where they were supposed to be. I then went through and setup things manually as I didn't want to risk contaminating anything up by using my saved settings.
After going through all this, my speeds are fine and all my port forwards work, even with NAT acceleration enabled. I have no idea what happened or why. So, if you're having this issue, and are open to trying it, a factory reset and then manual setup might help. But, YMMV. No guarantees this will work for anyone else.
A full reset, when warranted, works almost 100% of the time (if it's not actual hardware, firmware, or misconfigured settings).
