Has anyone else been having issues getting the port forwarding to work on this router with the latest Merlin AC68U firmware loaded on it? I can't, for the life of me, get it to open any ports. UPnP works fine, but port forwarding doesn't seem to work. I am using portchecktool.com to test the ports. I have tried several on my wired computer as well as the X-Box360, and both cannot get ports to open up. Are there any specific volly of settings that must be set just right in other menus and options to get it to forward the ports? Thanks in advance.
Update: I was able to temporarily get around the issue of only opening up the X-Box360 by limiting the External and Internal port ranges for UPnP to 3074 in all 4 boxes. Hopefully the router actually does the job of only using this port in UPnP and not just displaying the settings as visual eye candy. I really don't want to roll back to the ASUS firmware, as someone suggested that the problem could be with the Merlin Firmware.
