Port-Forwarding missing data (RT-AC68U-Merlin384.12)
marius_rg
Hi guys,
since the recent FWs my port fw list has been empty and no matter what I add, when I go back or refresh the page, the newly added entry is again missing.
If I do from ssh "nvram get vts_rulelist" it doesn't show anything.
Thank you.
Maybe you've run out of free space in NVRAM. Check it on the Tools - System Information page.
If you ever used OpenVPN in the past, there might be some leftovers key/certs wasting nvram space (as these are now stored in the jffs partition).
Create the following script on your router and run it to remove these from nvram.
#!/bin/sh
echo "Removing unused cert/key from nvram..."
for i in 1 2 3 4 5
do
    nvram unset vpn_crt_client$i\_ca
    nvram unset vpn_crt_client$i\_extra
    nvram unset vpn_crt_client$i\_crt
    nvram unset vpn_crt_client$i\_key
    nvram unset vpn_crt_client$i\_crl
    nvram unset vpn_crt_client$i\_static
done
for i in 1 2
do
    nvram unset vpn_crt_server$i\_ca
    nvram unset vpn_crt_server$i\_dh
    nvram unset vpn_crt_server$i\_ca_key
    nvram unset vpn_crt_server$i\_extra
    nvram unset vpn_crt_server$i\_client_crt
    nvram unset vpn_crt_server$i\_crl
    nvram unset vpn_crt_server$i\_crt
    nvram unset vpn_crt_server$i\_key
    nvram unset vpn_crt_server$i\_static
    nvram unset vpn_crt_server$i\_client_key
done
nvram commit
echo "done."
Thank you, that cleared a bit the usage
NVRAM usage
54267 / 65536 bytes
That should be confortable enough for regular usage, as long you don't enter a lot of DHCP static leases with long hostnames.
