If you define port forwarding rules for certain devices, and such devices are also selected for VPN, then port forwarding rules are ignored.
Use case is such: I have devices that need to use certain ports. when using them without VPN, everything works OK.
When using those same devices through a VPN client , port forwarding rules are ignored. NAT is applied through VPN connection with disregard to rules.
Now granted, not all OpenVPN support all ports but for those that do, this prevents using those devices with VPN.
Required Fix: implement port forwarding rules for connections using VPN clients.
