Port forwarding not working on RT-AC68U
Florin
Hi all,
I am running Merlin v.384.3 on an RT-AC68U.
The weird thing that happened is that all the port forwarding settings I had are now gone.
The bigger issue is that I am unable to add new ones. I complete the fields, hit the plus button then "apply", but after that the list is empty again.
I tried resetting, but no change.
Anyone else is having the same problem?
Anyone has any hint for me to try?
Thanks!
Check your nvram utilization on the Tools>Sysinfo page. If free space is around 3000 bytes or less, you'll have various problems including saving port forwards.
Hi all,
Thanks!
Hi Florin,
I upgraded yesterday to 384.3 and found that before I did a 'restore to factory defaults', all kind of weird behavior was happening, e.g. with storing certificate info, etc. Did you do a restore to factory defaults after your install? If not, you can give that a try.
Hi Florin,
I did Initialize
