Port forwarding not working (RT-AC66U with 380.70)
Rnzv
I'm trying to upgrade my router. Going from a Netgear wndr3700 with stock firmware to an Asus RT-AC66U with asuswrt-merlin (versions 380.70). Everything works fine apart from the port forwarding. It works perfectly on the Netgear so hereby i'm concluding that the problem lies with the Asus router. I'm completely out of ideas though.
Netgear port forwarding:
Asus port forwarding:
Asus WAN settings:
What i also tried:
- Turn off the firewall.
- Set 10.0.0.101 as a DMZ.
I'm testing this by accessing deluge / SSH from my phone without being connected to WIFI.
Anyone got any ideas?
Thanks in advance!
The only thing I can think of is if you have enabled SSH access to the router from WAN. In which case there would be a conflict on port 22.
Could be. However that is why i'm testing with Deluge on port 8112 as well. Same behavior there.
