NighthawkFoo
I recently upgraded an Asus RT-N66U running DD-WRT to an Asus RT-AC86U with Merlin version 386.3_2. I have a Raspberry Pi 4 as a home server with a static IP of 192.168.1.99. With DD-WRT, I was able to forward ports from the outside to the Pi so I could access it when away from home. I was forwarding ports for ssh, HTTP, and HTTPS.
After upgrading to the RT-AC86U, I have not been able to get port forwarding working. The Pi hasn't changed, and is plugged directly into the router via Ethernet. It's still listening for traffic, and I can connect to it when I'm on my home network on all the expected ports. I've played with the port forwarding settings in the router web UI, but they don't make a difference. I tried logging in to the router via ssh, and using iptables commands manually to setup port forwarding, but that didn't work either. I was able to see the forwarding rules in the iptables output, but I still haven't been able to connect to my Pi from an external machine.
I feel like I'm missing something obvious here, but I don't know what that might be. Does anyone have any suggestions?
