All,
I recently purchased a Asus RT-N66U router and was a former Tomato firmware user. I originally flashed it with latest TomatoUSB by Shibby version -which was a few years old from 2015 and found I got very poor Wireless power -especially on the 5 G band and was very disappointed especially since I really liked Tomato and had used in on several Routers in the past
I did some research and found out about Asus-wrt Merlin and how they used the original wireless drivers from the Stock Firmware and decided to try it and wow did it make a difference in my wireless range - especially on 5 G
I really like the software and the Gui - beautiful Gui
I have been going through all the features and have used it for about a week now and had a hard time locating the section that shows RX/TX and RSSI at the connected wireless clients as they had in Tomato and thought it was not available but then I finally did locate it in the new software in the section called System log > Wireless log. This gives you a snapshot of the quality of your connection at all of your wireless clients on your network and is very valuable information to have.
However I noticed that the RX portion of the RX/TX RSSI field only seems to display ??? and once in awhile posts a very low number in that field so something seems wrong there - the TX and RSSI field display correctly
I am hoping there may be an easy fix for this or a bug fix in a newer version
as I really miss this working 100 % correctly and am hoping someone else has seen this or has an answer
I believe it to be a bug at this point and I have the newest version of
Asuswrt-Merlin from the website Firmware:380.69_2
Hopefully if this is a bug it can be corrected in newest version update
Thanks !
KMN
Thanks !
KMN
