Possible to route certain sites through WAN and all others through Wireguard?
ASadani
Hi All, I'm on 3006.102.3 with BE86U. I have set up wireguard for certain clients, and it works very well.
However, I want to route certain domains through WAN and not through VPN.
For example, I want to route *.noon.com to go through WAN. For some reason, these sites detect data center IPs and block the connection.
I have read up on VPN director, but those work only for OpenVPN. Not sure if there is a feature somewhere.
Appreciate your help.
Thanks a lot for this. It works beautifully. It took me a couple of hit and misses but finally got it to work. Really good. Thanks so much
I could make this work for all other sites that are blocked over vpn. except the main one that I started this effort for. When I add the domain www.noon.com It does not route it through wan. Its just this site. I've tried pinging noon.com and it resolves to e285185.a.akamaiedge.net. I've added the akamai domain as well but that too does not work. Its just this domain that I cannot figure it out.
Below is the extract from the policy. I've also done the query when disconnected from wireguard but it does not work. Very confused
Policy Name: noon
Interface: wan
Verbose Logging: Disabled
Private IP Addresses: Disabled
Add CNAMES: Disabled
Domains:
www.noon.com
