Possible to setup N66U to run 2 web servers on 2 different machines?
chrisk
Is it possible to configure the N66U to run apache on 2 different machines but both using port 80?
I have tried using 81 but it just wont open.
I have 800 and 801 open but 81 will not open on my machine. I even tried dmz and still cant see it. Could it be something on the machine?
Thanks,
Chris
How are you opening the ports, with the firewall?
This should be in /jffs/scripts/firewall-start:
#!/bin/sh
iptables -I INPUT -p tcp --destination-port 81 -j ACCEPT
Then:
chmod a+rx /jffs/scripts/firewall-start
Reboot and 81 should be open.
Then setup Apache to do Virtual Hosts and this should resolve the 2 ips on the same lan with Apache running issue.
http://httpd.apache.org/docs/2.2/vhosts/
Specifically, IP Based Virtual Hosts:
http://httpd.apache.org/docs/2.2/vhosts/ip-based.html
You can setup "pund" with optware which is a reverse proxy. It will redirect recuests depending on the url you are trying to access.
J Home setup ASUS N Routers & Adapters 8
izak N66U ARP Compromised? ASUS N Routers & Adapters 1
