Potential acsd soft brick bug
Vexed
I'm just leaving this here in case I actually found anything of note. If not just disregard. My setup is an RT-AC68U with Merlin 384.14_2.
Scenario 1.
I was pentesting with mdk4's packet fuzzer using assorted flags. After a few minutes of this I noticed packets to/from WAN would randomly drop out for 20s at random. Nothing unusual seemed to appear in the logs. I reflashed the firmware but it didn't fix it. After about a day the dropouts cleared up on its own.
Scenario 2.
I was pentesting with mdk4's 'a' flag (fake clients) on a different router I owned. After about 30 minutes of pentesting I noticed all of the RT-AC68U's ethernet devices could not communicate with anything on LAN. Nothing related to ethernet worked properly. No devices could get packets to/from WAN either. I rebooted the device. DHCP would not give any of my ethernet devices a lease. On my ethernet devices I could use a static IP and every reboot there was a 1 minute window where I could access the router's web interface (which lagged) or SSH to it before the dropouts began. My wireless devices had no problem, I could access things on LAN and the web interface did not lag.
I was unable to resolve the router's glitched state over its interface. I tried reflashing the firmware and factory clearing its settings on the admin page. Even on the new router setup page my ethernet would drop out after about 1 minute of booting. The only way I could fix it was to do a full reset by holding down all the reset buttons, hitting "clear nvram" on the recovery page and repeating this process a few times. Then the dropouts stopped and I could restore my nvram settings and JFFS and there were no problems.
The logs had nothing unusual besides some acsd statements I had never seen before, like doing a DFS switch due to the 2.4 GHz network scan. If this bug exists it's probably very low level in the hardware somehow.
Sounds like you discovered your version of the Nuclear Reset. :)
