lluke
Hi All,
while investigating some issues with my PPPoE connection it seems that I've to configure the Host-Uniq tag to a specific value.
The value I should provide is
which seems to be incompatible with Asus WRT Merlin (tested on 386.5_2) since it is 61 chars length and the system has an hard limit to 32 characters.
As per the RFC 2516 the Host-Uniq can be of any value and length
Trying to force a longer value through APIs I'm getting the following error from the logs
Is there any reason for this limitation? Is there any possibility to get rid of it or is it possible to fix this behavior in a future release of the firmware?
1ced6f301223aaaaaaaa04000000aaaaaaaa4621426f78202020aaaaaaaa
0x0103 Host-Uniq
This TAG is used by a Host to uniquely associate an Access
Concentrator response (PADO or PADS) to a particular Host request
(PADI or PADR). The TAG_VALUE is binary data of any value and
length that the Host chooses. It is not interpreted by the Access
Concentrator. The Host MAY include a Host-Uniq TAG in a PADI or
PADR. If the Access Concentrator receives this TAG, it MUST
include the TAG unmodified in the associated PADO or PADS
response.
httpd: nvram_check fail: nvram wan_pppoe_hostuniq over length (60 > 32)
