Hi
Because of double NAT I switch to modem mode only on my provider modem/router and connect the ROG AX6000 over PPPoE to the internet. It works good but the ROG boot much faster than my modem and won't reconnect to the internet until I reboot the AX6000 again.
The problem here is even after 5 min. the ROG don't try again to reconnect to the internet. I need to reboot the AX6000 and than it works again.
Can I fix that?
I also got a old Fritzbox and think to use it like modem and router, connect the AX6000 over LAN but than I will get the problem.with double NAT?
Regards
Can I fix that?
Regards
