PPTP client problem
ozgurcnbyz
Sorry if this has been discussed before but i am not good at searching forums.
I have a VPS at linode which i setup pptp server along with openvpn. i can connect to the pptp server from any device successfully except my ac66u which produces the following logs
Jan 5 12:09:47 pptp[1588]: Plugin pptp.so loaded.
Jan 5 12:09:47 pptp[1588]: PPTP plugin version 0.8.5 compiled for pppd-2.4.5, linux-2.6.22.19
Jan 5 12:09:47 pptp[1589]: pppd 2.4.5 started by admin, uid 0
Jan 5 12:09:48 pptp[1589]: Using interface ppp5
Jan 5 12:09:48 pptp[1589]: Connect: ppp5 <--> pptp ()
Jan 5 12:09:48 pptp[1589]: CHAP authentication succeeded
Jan 5 12:09:48 pptp[1589]: LCP terminated by peer (MPPE required but peer negotiation failed)
Jan 5 12:09:51 pptp[1589]: Connection terminated.
Jan 5 12:09:51 pptp[1589]: Modem hangup
ok got it working. found the solution in another thread. As merlin stated asus router somehow disables MPPE. below is the commands to run on the ssh
nvram set vpnc_pptp_options_x="+mppe-128"
nvram commit
