PPTP Master Branch
Shonk
Since the 6065 Merge 12 days ago
PPTP hasnt been working for me
It all dials in fine but isnt working
Not in a rush in any way for this
clearly i know its unfinished code
Just pointing out the problem
Incase you havnt noticed it
Before Device Dials in as expected
C:\>ping 192.168.0.200
Pinging 192.168.0.200 with 32 bytes of data:
Reply from 192.168.0.28: Destination host unreachable.
Ping statistics for 192.168.0.200:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
After Device Dials In
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
Oh on a side note
I used to run a second openwrt ap that handled dhcp and dns
and recently decided to do away with it so i have the ac66u doing dhcp now
I have always used 28 day dhcp lease's for some reason the max on
asuswrt is 7days (604800)
The router handles larger leases fine i set it up via the command prompt/nvram
for 28days (2419200) and its all fine but ofc i cant change any setting in the dhcp server page
due to it moaning about the dhcp lease time
Can i put a request in for the web interface to allow larger dhcp leases plz
ofc no rush but would be nice to have
example of 28days working fine.
Why don't you use static DHCP?
And, yes, PPTP does not work for me either in 378.54_1. Can't even establish connection.
PPTP server? PPTP client? What's in your system log?
I'll need much more info than this to even begin to have any idea as to what could be the problem, if there is.
Why would i want to go around messing with static ip's on 60+ devices
when i can set perm reservations and give them 28day leases
each device will call home every 14 days and renew its "static lease"
All looks good and has been working for months with zero problems
apart from since the 6065 merge
i have totally deleted the source and did a fresh pull to ensure it wasnt a local problem
i also did a factory reset of the router nvram to ensure it wasnt something nvram related
dial in from the router looks good
this is mips rt-ac66u btw
i have an ac56u running a build pre 6065 merge Thu Jun 4 05:25:31 UTC 2015
and pptp still works fine
I have always had the windows machine dial in to my lan and not use the default gateway
as its just for lan traffic
e.g. it uses its own connection for any traffic apart from smb and such
Jun 21 23:31:36 pptpd[1019]: CTRL: Client 80.edit control connection started
Jun 21 23:31:36 pptpd[1019]: CTRL: Starting call (launching pppd, opening GRE)
Jun 21 23:31:37 pptp[1020]: Plugin pptp.so loaded.
Jun 21 23:31:37 pptp[1020]: PPTP plugin version 0.8.5 compiled for pppd-2.4.7, linux-2.6.22.19
Jun 21 23:31:37 pptp[1020]: pppd 2.4.7 started by admin, uid 0
Jun 21 23:31:37 pptp[1020]: Using interface ppp10
Jun 21 23:31:37 pptp[1020]: Connect: ppp10 <--> pptp (80.edit)
Jun 21 23:31:37 pptpd[1019]: CTRL: Ignored a SET LINK INFO packet with real ACCMs!
Jun 21 23:31:37 pptp[1020]: found interface br0 for proxy arp
Jun 21 23:31:37 pptp[1020]: local IP address 192.168.0.1
Jun 21 23:31:37 pptp[1020]: remote IP address 192.168.0.200
Umm it seems to have been some weird bug
the device dials in and doesnt use the default gateway as its just for local traffic
e.g. smb and such
the same setup has been fine for months
Dialed in with default gateway unticked = not working (same config thats been used for months)
Dialed in and ticked use default gateway = worked fine
Dialed in with default gateway unticked = worked fine
not really sure what to say it is a bug but not sure how using the default gateway fixed it
as it shouldnt have
