PPTP server broken when using selective routing over OpenVPN
yoggit
Hi!
I've been looking around for a while for a solution to this problem, but I haven't had any luck.
The problem is that when I enable my OpenVPN client, which triggers the openvpn script and applies selective routing as per a script very similar to the one found here - https://github.com/RMerl/asuswrt-merlin/wiki/Policy-based-routing-(manual-method) , I can no longer VPN into my PPTP server from outside the local network. I only have a single host marked with '0' to use the tunnel.
Anyone got this working successfully??
I'm running version 374.43 on RT-AC66U.
Thanks!
-yoggit
