PPTP Server dead since 374.41 upgrade
EdisonW
Hello all,
I've noticed my N66U's PPTP server no longer allows any connections since upgrading it to 374.41.
Here's one of my log entries:
May 12 12:04:37 pptpd[514]: CTRL: Client xxx.xxx.xxx.xxx control connection finished
May 12 12:05:43 pptpd[523]: CTRL: Client xxx.xxx.xxx.xxx control connection started
May 12 12:05:43 pptpd[523]: CTRL: Starting call (launching pppd, opening GRE)
May 12 12:05:43 pptp[524]: Plugin pptp.so loaded.
May 12 12:05:43 pptp[524]: PPTP plugin version 0.8.5 compiled for pppd-2.4.5, linux-2.6.22.19
May 12 12:05:43 pptp[524]: pppd 2.4.5 started by eyservices, uid 0
May 12 12:05:43 pptp[524]: Using interface ppp10
May 12 12:05:43 pptp[524]: Connect: ppp10 <--> pptp (xxx.xxx.xxx.xxx)
May 12 12:06:13 pptpd[523]: CTRL: EOF or bad error reading ctrl packet length.
May 12 12:06:13 pptpd[523]: CTRL: couldn't read packet header (exit)
May 12 12:06:13 pptpd[523]: CTRL: CTRL read failed
May 12 12:06:13 pptpd[523]: CTRL: Client pppd TERM sending
May 12 12:06:13 pptp[524]: LCP: timeout sending Config-Requests
May 12 12:06:13 pptp[524]: Connection terminated.
May 12 12:06:13 pptpd[523]: CTRL: Client pppd finish wait
May 12 12:06:13 pptp[524]: Terminating on signal 15
May 12 12:06:13 pptp[524]: Modem hangup
May 12 12:06:13 pptp[524]: Exit.
May 12 12:06:13 pptpd[523]: CTRL: Client xxx.xxx.xxx.xxx control connection finished
I haven't changed any settings on my clients, iOS 7.1.1, OS X 10.9.2, and Windows 8.1 Update 1 devices since the upgrade.
Any ideas on this one?
Cheers
The latest firmware is 374.42
Read the changelog (in zipfile), it may be solved.
Unfortunately nothing mentioned in change log for PPTP in the new version:
374.42 (9-Mai-2014)
- NEW: Merged with Asus's 374_5656 GPL.
- NEW: Added Comodo Secure DNS to supported DNSFilter services
- FIXED: Download2 folder wasn't selectable anymore on the
Media Server page.
- FIXED: Pass correct valid and preferred lifetime to radvd when
using DHCPv6-PD (Patch by pinwing)
- FIXED: IPv6 connectivity could be lost after 1-2 hours due
to the time shift caused by NTP at boot time
(Patch by pinwing)
- FIXED: Various IPv6 connectivity issues related to services
being (re)started at the wrong time, or twice.
(Patch by pinwing)
- FIXED: Build system would sometime try to use the local system's
header/libs - use a pkg-config wrapper to avoid this
issue (Patch by ppuryear)
- FIXED: Erratic 5G led blinking behaviour as the watchdog's software-
based blinking was constantly writing to the wireless chip's
registers for led control. (AC68)
- FIXED: LEDs weren't all turning back on when coming out of
Stealth Mode (AC56)
- CHANGED: Make the router use dnsmasq for internal name
resolution rather than directly using the WAN DNS.
- CHANGED: Upgraded OpenVPN to 2.3.4.
- CHANGED: Upgraded miniupnpd to 1.8.20140422 (PCP-related fixes)
