Hello,
I would like to have some help with a log that I don't understand (and didn't find a reasonable explanation on web):
1-I setup a VPN server (PPTP)
2-Create an user and pass
3- Connected with my cellphone without any problem (My cellphone acquires the routers public IP)
4-Tried a different device (satellite box) and it doesn't work . It reaches the router but can't connect
5-Tried different configurations on encryption (even with "No encryption), change MRU and MTU to the minimum and nothing...
I can see something suspicious in the log (Received bad configure-ack) but didn't find any help on web/forum.
Someone could guide me to understand what's happening and what can I ajust to make it work, please? (I don't have any parameters to tune on device side just User/pass/address.
The log is:
"Apr 12 23:37:34 pptpd[25761]: CTRL: Client 89.115.148.48 control connection started
Apr 12 23:37:34 pptpd[25761]: CTRL: Starting call (launching pppd, opening GRE)
Apr 12 23:37:34 pptp[25763]: Plugin pptp.so loaded.
Apr 12 23:37:34 pptp[25763]: PPTP plugin version 0.8.5 compiled for pppd-2.4.7, linux-2.6.36.4
Apr 12 23:37:34 pptp[25763]: pppd 2.4.7 started by Kraussvan, uid 0
Apr 12 23:37:34 pptp[25763]: Using interface pptp0
Apr 12 23:37:34 pptp[25763]: Connect: pptp0 <--> pptp (89.115.148.48)
Apr 12 23:37:35 pptp[25763]: Received bad configure-ack: 12 06 01 00 00 60
Apr 12 23:37:38 lldpd[350]: removal request for address of 192.168.7.1%37, but no knowledge of it
Apr 12 23:37:38 pptp[25763]: Cannot determine ethernet address for proxy ARP
Apr 12 23:37:38 pptp[25763]: local IP address 192.168.7.1
Apr 12 23:37:38 pptp[25763]: remote IP address 192.168.10.2
Apr 12 23:37:39 kernel: ppp: compressor dropped pkt
Apr 12 23:37:39 kernel: ppp: compressor dropped pkt"
and so on......
Thank you
Best
Kr.
The log is:
and so on......
Thank you
Best
Kr.
