"Preferred wifi uplink AP" setting doesn't work.
wsalopek
I have 3 routers:
Main router: RT-AC86U
Mesh: RT-AC66U B1
Mesh: RT-AX1800S
They are set up in a straight line - so the 66U is BETWEEN then 86U and 1800S. but the 1800S always connects to the 86U (and with a "weak" signal) instead of the 66U, which is 1/2-way in between (and connected to the main router via ethernet).
I have selected the 66U as the "preferred wifi uplink AP" in the 1800S settings - but the 1800S seems to ignore that setting.
I have rebooted a thousand times, in various orders. I have "optimized" another thousand times. I deleted the 1800S from the mesh network, reset it, and re-added it.
Any ideas how I can force the 1800S to connect to the 66U instead of the much farther away 86U?
Thanks...
Only with whatever option is available in AiMesh settings page. If it doesn't work - you're out of luck because your AC-class routers are both End-of-Life. No more firmware development not fixes are expected. One possible workaround is to run your RT-AC86U as main router and your wired RT-AC66U B1 as AiMesh router in AP mode with wireless RT-AX1800S node attached to it. You'll lose central management screen (nothing to manage there much anyway), but it may do what you want*. You can have the same SSIDs on all 3x routers just like before and the clients will roam between them just like before.
* - hopefully AiMesh has enough Ai in it to distinguish between 2x APs with the same SSID. Test and see.
