OzarkEdge
Part of the Furniture
I'm about to order a set of ScreenBeam MoCA 2.5 adapters ECB7250:
Amazon.com: ScreenBeam Bonded MoCA 2.5 Network Adapter for Highest Speed Internet, Ethernet Over Coax - Starter Kit (Model: ECB7250K02)
ScreenBeam appears to be a retail outlet for Actiontec(?), so I'm assuming these adapters are nearly the same/good as Actiontex ECB7250s sold to ISPs, etc. (not available in the retail channel). 'Good as' including Actiontec-sourced firmware and documentation. These adapters (Actiontec) appear to use the latest MaxLinear MxL93712 chipset.
Application will be over coax dedicated to MoCA and two OTA TV antennas (coupled and preamped; no cable modem/DOCSIS signaling). I plan to add two POE/LPF/MoCA filters, one at each end to stop the MoCA signal from reaching the preamp/coupler/antennas and the TV/AVR tuners.
A few concerns:
o Any feedback on the ScreenBeam adapter choice?
o Any suggestions for sourcing the MoCA filters? The goCoax filters look good: OT-LPF-1002 | goCoax
o Can I inject the antenna preamp power at the media center end of the MoCA run (like I'm doing now), or should I place it beyond the MoCA filter at the antenna end, just below the preamp?
o I assume I can use a non-MoCA splitter beyond the MoCA filter at the media center end(?)
Thanks for any advice!
OE
A few concerns:
OE
