Hi All,
I'm looking to configure printing from a guest network to a printer, which is in the main network. I'm using AsusWRT-Merlin 3004.388.8_2 on RT-AX88U Pro. I have AiMesh with one RT-AX88U Pro node and I have 2 guest networks which I need to be available on the node as well.
I also have a USB printer, connected to the main router, which I would like to be used from the main network as well as one of the guest networks. I tried with iptables and with ebtables, I looked at @Martineau's scripts, but I couldn't make it work from the "Guest" guest network (see below). The printer works flawlessly from the main network, of course. I'm sure that I'm missing something and I would appreciate your help.
Here are the details:
What I have tried:
and
Neither works.
Thank you!
- Main router: 192.168.1.1, RT-AX88U PRO
- AiMesh node, RT-AX88U PRO
- "IoT" guest network, Guest Network #1 on 2.4 GHz, wl0.1, br1, no need to access the printer, 192.168.101.0/24, access to main LAN disabled in order to get a different IP range from the main network
- "Guest" guest network, Guest Network #1 on 5 GHz, wl1.1, br2, this is the guest network which I would like to access the printer, 192.168.102.0/24, access to main LAN disabled in order to get a different IP range from the main network
- Both "IoT" and "Guest" guest networks have to be available on the AiMesh node, i.e. I cannot use YazFi and they both have to be set as Guest Network #1
What I have tried:
Bash:
iptables -I FORWARD -i br2 -o br0 -d 192.168.1.1/32 -j ACCEPT
and
Bash:
ebtables -I FORWARD -p IPv4 -i wl1.1 --ip-dst 192.168.1.1 --ip-proto tcp -j ACCEPT
ebtables -I FORWARD -p IPv4 -o wl1.1 --ip-src 192.168.1.1 --ip-proto tcp -j ACCEPT
Neither works.
Thank you!
