I have bought two weeks ago this router for replacing my old Netgear, after I have updated the router to the last firmware (reset after the update) and configure it, I have found some difficulties about the "stability" of this router.
I explain better my problem: sometimes happens that my ADSL modem (TP-Link TD-8616) lose ADSL connection but after some seconds, the modem restore it but the router seems to be not updated with the latest IP Address my provider gives to my modem.
The only working solutions I have found in these days are:
- Restart phisically the router pressing the on/off button
- Go into the website of the router, click on the "symbol of the World" (where it shows me Internet status) and turn off and some seconds after turn on again my Internet connection
I have already tried to reset the router and configure only the basic settings, but this problem persists. I can wait one minute, ten or whatelse, but the problem isn't fixed until I do one of the two action I have described above.
I have tried to do a firmware upgrade with the merlin one, but the problem is the same.
Is there a way to tell the router to check if the ADSL connection has the same IP Address that router shows on the main webpage or it is changed for the problem I have described above?
Thank you for anyone will answer and sorry for my english, I hope you can understand the problem
