Problem ASUS RT-AC66U with Merlin 378.53.0
necroraven
Hi ! I have the router of the title with the Merlin firmware ... I don't don't what happens but now I have 3 blue lights and it doesn't give me and ip or anything I already try the reset botton and nothing happens... Some days before this happens the router reset it self like 3 times .
Help ? Mayday ?
Help ? Mayday ?
Try turning the router on while you have the reset button pressed, then after a few secs release it. If the power led does not start flashing and you still have three LEDs on, then it means your router is defective.
I leave the router with out power for the night and know is working ...What I have to do to to wipe the put it like factory default ...
Power on the router while holding the WPS button wait about 10 seconds and release let router fully boot up. Now you will have a complete factory reset and Nvram will be cleared.
Do like Kel-L said, everything will be wiped and after when in GUI go to Admin tab and do "FACTORY DEFAULT" not Restore and reconfig from the beginning.Good luck
