Here's my situation:
I am a TimeWarnerCable subscriber and get my internet through them (300/20 "Ultimate"). I am using a 16x4 channel bonding modem (Arris-Motorola SB6183) and my speeds are excellent, 323+down, 21+ up. IPv6 is working fine with TWC these days.
My cable modem is connected to one of two RT-AC66U's I own which is set up to be in "router" mode, currently running Merlin 374.38_2 (I find that I prefer this over more recent builds...better power/bandwidth, seems to be speedier and I don't use the bells and whistles in the latest builds).
My "router" is located upstairs which gives complete coverage to the second floor bedrooms and a home office located upstairs, and also provides decent coverage to the front portion of our first floor. 5ghz and 2.4ghz are solid and speedy. So that's not an issue.
My second RT-AC66U is located downstairs, and it is set up to operate in "repeater" mode so that it provides a stronger signal to the rear of the house. It is running Merlin Build 374.41. I have it in "repeater" because I cannot get a wired Ethernet connection to the RT-AC66U located downstairs. The repeater itself is connected to a Belkin Gigabit 8 port switch, to which I have connected a Denon receiver, a Blu-Ray player, an HD-DVD player (now obsolete, but we still use it occasionally), a home theater computer (running Win 7), a Toshiba 56" TV (not a smart TV). The "repeater" also broadcasts wireless 5gh and 2.4ghz channels to several wireless devices located in downstairs (an Acer Desktop with both 2.4 and 5ghz adapter) and an HP Officejet Pro 8625 printer that has only 2.4ghz and is connected wirelessly to the "repeater".
Download and upload speeds are really good on all clients, both wired and wireless connected to the "repeater" Those clients connected to the Belkin Gigabit switch downstairs (connected to the "repeater") are getting 280+ down (almost as good as being connected via Ethernet to the upstairs router and/or the cable modem directly). So I'm getting way better speeds than the "halving" that would occur if I was in "bridge" or AP mode with the downstairs unit (and besides, I can't run in AP mode because I cannot get an Ethernet cable to the downstairs RT-AC66U).
Both of the RT-AC66U's have different SSIDs. Upstairs it's "ASUS" and "ASUS 5G" and downstairs it's "ASUS 2nd" and "ASUS 5G 2nd" (mostly so I can determine to which I am connected at any given point, enabling me to tune channels and bands better to reduce/avoid interference from the neighbors).
Here's the issue: IPv6 works just fine on my upstairs "router" (the one functioning as a router). IPv6 however, does not work at all on the "repeater".
All of the devices on the "router" can and do use IPv6. None of the devices on the "repeater" can access IPv6. If I connect a downstairs wireless client to the "repeater" and then check the adapter's properties, it says (in Windows 7/8.1) that IPv6 is not connected. If I then connect the same wireless device to the upstairs "router" wirelessly (on either 5ghz or 2.4 ghz channels), the device will use IPv6. So I know it's not individual device settings that prevents IPv6. It's the "repeater" itself that does not enable IPv6.
I have searched all the SNB forums and other forums on the interwebs, and no one seems to have any answers about how to get IPv6 working on the repeater. Several people asked about it, but no one has suggested an answer. One person posted about two months ago and then concluded that he had wasted too much time on the issue and simply purchased N13AP's.
Any suggestions? Is it possible to get IPv6 working on an Asus RT-AC66U when running in "repeater" mode?
Any and all help greatly appreciated.
