wheelq
Two of my routers are running on different networks in different locations.
I have set up OVPN servers on both routers, and I have exported ovpn profile files from both of them
After importing the ovpn profile files I am able to connect to both using tunnelbrick.
Both tunnels work fine, which means I am able to browse remote local LAN as well as websites.
The problems start when I import one of the profiles onto the routers vpn client and I activate the connection.
Bas on the syslog, I can see that the connection has been established but:
- I can not reach any of the remote local LAN devices
- I can not reach any webpages.
I thought there might be something wrong with my machine, but I run telnet session against remote LAN devices as well as random pages - no response.
Has anyone got any idea how to make this work?
01 Remote VPN Server config
02 Remote VPN Server exported ovpn profile
04 Local VPN syslog
04 Local VPN syslog
