Problem to add a static route to particular network via particular gateway using GUI
kwk_kwk
I'm trying to add a custom route between 2 routers from Router1 to Router2:
Router1
WAN - 10.10.218.1/255.255.255.0
LAN - 192.168.121.0/255.255.255.0
Router2
WAN - 10.10.170.18/255.255.255.0
LAN - 192.168.145.0/255.255.255.0
Router1 route table:
Kernel IP routing table
Destination Gateway Genmask Flags MSS Window irtt Iface
0.0.0.0 10.10.218.1 0.0.0.0 UG 0 0 0 eth0
10.10.218.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
10.10.218.1 0.0.0.0 255.255.255.255 UH 0 0 0 eth0
127.0.0.0 0.0.0.0 255.0.0.0 U 0 0 0 lo
192.168.121.0 0.0.0.0 255.255.255.0 U 0 0 0 br0
I need to add a static route on Router1 to the LAN on Router2.
If I add the route manually all works perfetly:
route add -host 10.10.170.18 dev eth0
route add -net 192.168.145.0 netmask 255.255.255.0 gw 10.10.170.18 eth0
10.10.170.18 0.0.0.0 255.255.255.255 UH 0 0 0 eth0
192.168.145.0 10.10.170.18 255.255.255.0 UG 0 0 0 eth0
But if I add the route using router GUI:
IP-address Network mask Gateway Metric Interface
10.10.170.18 255.255.255.255 0.0.0.0 - WAN
192.168.145.0 255.255.255.0 10.10.170.18 - WAN
The first line is transforming to command (adding particular gateway)
route add -host 10.10.170.18 gw 10.10.218.1 dev eth0
10.10.170.18 10.10.218.1 255.255.255.255 UGH 0 0 0 eth0
and after issuing the second command:
I get the error:
route: SIOCADDRT: Network is unreachable
How can I add a static route to particular network via particular gateway using GUI?
To be honest, I don't know if the GUI route function was ever meant to function this complex. It is a home router after all.
Since you got the routes established the old fashioned way (and, in my opinion the most reliable way), why not put it all in a script and call the script from the services-start user script (or just put the routing statements in services-start).
Firewall-start may be a better spot (wait until the firewall is up).
Your routes don't seem to make much sense. Can you explain how routers 1 and 2 to are connected to each other (LAN to LAN, WAN to LAN, or LAN to WAN), or is there another router in between?
Both routers are located in isolated ISP WAN 10.10.*.* and can access each other by WAN1 - WAN2.
Enery router serves its location and has its private LAN 192.168.x.*.
I need configure access from LAN1 to LAN2 and vice versa.
I understand this way but it requires a flash drive to collocate the script, but I'd like not to use it.
Put your script in the /jffs/scripts directory with the services-start, no USB drive required.
Nope, just ensure you have "enable user scripts" enabled in Administration - system.
