Problem when rebooting RT-AC56U in command line
kcobain1992
Hello,
I wanted to report an issue: in SSH, after issuing the command reboot, the router hangs in an inconsistent state, rather than cleanly finishing the reboot cycle.
When trying to access any web page, it redirects to 192.168.1.1 and displays the message shown in the screenshot below.
After manually rebooting (from the switch at the back) everything comes back to normal.
I'd like to know if I'm the only one having this issue.
Firmware version is 376.49_2
Vladimir
Check your System Log during the reboot to see if there's any additional info as to where it gets stuck in the shutdown.
Hello,
Vladimir
When you say "an inconsistent state", do you mean that the router is no longer working when the uploaded page is displayed ?
I'm asking because I did get this page and it had no effect on the router. When I got that page, I just remove the part of the URL other that http://192.168.1.1 and made "return".
I can't seem to pinpoint what causes it. Neither /jffs/syslog.log nor dmesg seem to show anything suspicious, but it's definitely happening each time I reboot the router from ssh. Now it seems to go away after logging in to its administration webpage.
My questions were:
1- when you see that page after the terminal reboot, is the router performing well at the same time?
2- when this situation happens, after correcting the url (by just keeping http://192.168.1.1 portion of the url), is the usual home page displayed ?
My questions were:
The first time when it happened, it would even block ping requests to 8.8.8.8, wouldn't let me log in, etc. I had to restart it the hard way.
But now I can open the config page (the answer to the second question is yes), and after I do so, it seems to start working again normally. That's why I need to investigate a little more.
A couple of possibilities.....
How long are you waiting after the reboot command to access the router? The router is actually still processing the reboot after all the LEDs come active. Try waiting about 2min and see if it still fails.
Do you have USB drives attached? As a test, try disconnecting the USB drives before the reboot and see if still fails.
