Hi, trying to do my first AiMesh setup moving away from Orbi. Had a AX88U for a while that worked great; just recently got an AX55 to connect as an AiMesh node.
- I was unable to get the node to connect wirelessly, so I plugged in an ethernet cable - that solved that piece.
- When I remove power (to move it from the 1-3 meters to the place I want the node) and plug it back in, it won't reconnect. Even if I leave it where I originally connected it and unplug it / plug it back in it will not reconnect unless the ethernet cable is connected. If I switch the backhaul connection priority to wifi, then even with an ethernet cable it won't reconnect.
Both routers are the latest stock Asus firmware.
Any ideas? TIA.
Any ideas? TIA.
