Problem with Alpha build 2
TheLyppardMan
I gave Smart Connect a try this morning, but after switching it off, I've found that I have lost control of the 2.4 GHz band; althought the GUI shows changes, in reality, I cannot rename the SSID or even turn the wireless radio off. Also, after rebooting, the router led for the 2.4 GHz band is off, but the radio is actually transmitting the same SSID as the 5 GHz band.
Alpha builds are unsupported, for experimental use only and there is a dedicated thread about this release. Better report your findings there.
People are discussing Alpha issues here:
Like already said, Alpha is unsupported.
