Problem with AX3000 v2
jplw
I found this in my logs. Any ideas what is going on?
Dec 11 09:31:22 roamast: [EXAP]Deauth old sta in 0 0: 1C:57:DC:27:61:91
Dec 11 09:31:22 roamast: eth2: disconnect weak signal strength station [1c:57:dc:27:61:91]
Dec 11 09:31:22 kernel: CPU: 2 PID: 1116 Comm: roamast Tainted: P O 4.19.183 #1
Dec 11 09:31:22 kernel: Hardware name: Generic DT based system
Dec 11 09:31:22 kernel: PC is at 0xb675092e
Dec 11 09:31:22 kernel: LR is at 0xb672d680
Dec 11 09:31:23 kernel: pc : [<b675092e>] lr : [<b672d680>] psr: 20000030
Dec 11 09:31:23 kernel: sp : b66d7d08 ip : ffffffff fp : b66d81fc
Dec 11 09:31:23 kernel: r10: 00000073 r9 : 00000000 r8 : b66d81d8
Dec 11 09:31:23 kernel: r7 : 0000001c r6 : 001a441d r5 : 00000021 r4 : 00000004
Dec 11 09:31:23 kernel: r3 : 00000000 r2 : 00000001 r1 : 00000018 r0 : 0000001c
Dec 11 09:31:23 kernel: Flags: nzCv IRQs on FIQs on Mode USER_32 ISA Thumb Segment user
Dec 11 09:31:23 kernel: Control: 10c5387d Table: 17bd004a DAC: 00000055
Dec 11 09:31:23 kernel: CPU: 2 PID: 1116 Comm: roamast Tainted: P O 4.19.183 #1
Dec 11 09:31:23 kernel: Hardware name: Generic DT based system
Dec 11 09:31:23 kernel: [<c0210c94>] (unwind_backtrace) from [<c020bc2c>] (show_stack+0x10/0x14)
Dec 11 09:31:23 kernel: [<c020bc2c>] (show_stack) from [<c07f0270>] (dump_stack+0x90/0xa4)
Dec 11 09:31:23 kernel: [<c07f0270>] (dump_stack) from [<c022dbd0>] (get_signal+0x658/0x680)
Dec 11 09:31:23 kernel: [<c022dbd0>] (get_signal) from [<c020b094>] (do_signal+0xcc/0x538)
Dec 11 09:31:23 kernel: [<c020b094>] (do_signal) from [<c020b6c4>] (do_work_pending+0xb4/0xd0)
Dec 11 09:31:23 kernel: [<c020b6c4>] (do_work_pending) from [<c0201070>] (slow_work_pending+0xc/0x20)
Dec 11 09:31:23 kernel: Exception stack(0xd3dd1fb0 to 0xd3dd1ff8)
Dec 11 09:31:23 kernel: 1fa0: 0000001c 00000018 00000001 00000000
Dec 11 09:31:23 kernel: 1fc0: 00000004 00000021 001a441d 0000001c b66d81d8 00000000 00000073 b66d81fc
Dec 11 09:31:23 kernel: 1fe0: ffffffff b66d7d08 b672d680 b675092e 20000030 ffffffff
Disable Roaming Assistant in Wireless, Professional. Asuswrt has it enabled by default for no reason. Reboot the router and monitor the logs.
I diabled it. After < 24 hours got more kernel messages, different this time:
Dec 11 16:29:15 crond[2222]: time disparity of 2421624 minutes detected
Dec 11 16:29:33 kernel: ^[[0;33;41mFCACHE ERROR: fc_config_mcast_group: Mcast: client has already JOINed the mcast group (duplicate JOIN)^[[0m
Dec 11 16:29:33 kernel: Mcast: new client info: group_addr<224.0.2.3> src_addr<0.0.0.0> is_ssm<0> tx_dev_p<dbf44800> wlinfo<0000> client_type<0> MAC<e0:bb:9e:2d:3d:4d> rtp_seq_chk<0>
Dec 11 16:29:33 kernel: rtp_seq_chk<0> mcast_excl_udp_port<0>
Dec 11 16:29:33 kernel: Mcast: new client: matches with: mcast_group<0> client_id<1>
Dec 11 16:29:33 kernel: ^[[0;33;41m[ERROR mcast] bcm_mcast_clientinfo_node_add,843: blog_activate failure^[[0m
Dec 11 16:29:33 kernel: ^[[0;33;41m[ERROR mcast] bcm_mcast_fc_flow_add,924: Error adding client info node^[[0m
Dec 11 16:29:33 kernel: is_ssm 0 grp 224.0.2.3 src 0.0.0.0
Dec 11 16:29:33 kernel: mcast_exclude_udp_port 0x0 rtp seq check 0
Dec 11 16:29:33 kernel: ***Client List***
Dec 11 16:29:33 kernel: to_accel_dev eth1 wl info 0x0 clientmac b0:e8:92:0c:a8:ef
Dec 11 16:29:33 kernel: ***Rx Info list***
Dec 11 16:29:33 kernel: rxinfo blog_p 0xdca66cc0
Dec 11 16:29:33 kernel: ^[[0;33;41m[ERROR mcast] bcm_mcast_blogrule_vlan_process,319: Unable to create flow, continue^[[0m
Do you have any issues using the router?
Unclear. I have intermittant loss of internet--which I am trying to get Comcast to fix--but also intermittant inability to ping local devices.
I must have Roaming Assistnt on or the system is useless in my environment. I hard reset everything and reconfigred from scrstch. I am still get frequent erors like:
Dec 23 08:51:08 roamast: eth2: disconnect weak signal strength station [06:af:f0:f2:ab:02]
Dec 23 08:51:08 kernel: CPU: 1 PID: 22192 Comm: roamast Tainted: P O 4.19.183 #1
Dec 23 08:51:08 kernel: Hardware name: Generic DT based system
Dec 23 08:51:08 kernel: PC is at 0xb669b92e
Dec 23 08:51:08 kernel: LR is at 0xb6678680
Dec 23 08:51:08 kernel: pc : [<b669b92e>] lr : [<b6678680>] psr: 20000030
Dec 23 08:51:08 kernel: sp : b6622d08 ip : ffffffff fp : b66231fc
Dec 23 08:51:08 kernel: r10: 00000073 r9 : 00000000 r8 : b66231d8
Dec 23 08:51:08 kernel: r7 : 00000006 r6 : 001a441d r5 : 00000021 r4 : 00000006
Dec 23 08:51:08 kernel: r3 : 00000000 r2 : 00000001 r1 : 00000000 r0 : 00000006
Dec 23 08:51:08 kernel: Flags: nzCv IRQs on FIQs on Mode USER_32 ISA Thumb Segment user
Dec 23 08:51:08 kernel: Control: 10c5387d Table: 0db6c04a DAC: 00000055
Dec 23 08:51:08 kernel: [<c0210c94>] (unwind_backtrace) from [<c020bc2c>] (show_stack+0x10/0x14)
Dec 23 08:51:08 kernel: [<c020bc2c>] (show_stack) from [<c07f0270>] (dump_stack+0x90/0xa4)
Dec 23 08:51:08 kernel: [<c07f0270>] (dump_stack) from [<c022dbd0>] (get_signal+0x658/0x680)
Dec 23 08:51:08 kernel: [<c022dbd0>] (get_signal) from [<c020b094>] (do_signal+0xcc/0x538)
Dec 23 08:51:08 kernel: [<c020b094>] (do_signal) from [<c020b6c4>] (do_work_pending+0xb4/0xd0)
Dec 23 08:51:08 kernel: [<c020b6c4>] (do_work_pending) from [<c0201070>] (slow_work_pending+0xc/0x20)
Dec 23 08:51:08 kernel: Exception stack(0xd383bfb0 to 0xd383bff8)
Dec 23 08:51:08 kernel: bfa0: 00000006 00000000 00000001 00000000
Dec 23 08:51:08 kernel: bfc0: 00000006 00000021 001a441d 00000006 b66231d8 00000000 00000073 b66231fc
Dec 23 08:51:08 kernel: bfe0: ffffffff b6622d08 b6678680 b669b92e 20000030 ffffffff
Is my unit defective? Is the latest firmware (3.0.0.4.386_49674) known to be bad?
What's the system? I found Roaming Assistant not working at all on some firmware versions and it's useless for a single router even if it's working.
AX3000 v2 Router, 66U_B1 node. When it was turned off, a Macbook that had connected to the node remained connected (poorly) to the node when operated nearer the router. Zoom kept freezing. Thid never ever happened with Roaming Assistant on.
It's unlikely Roaming Assistant is involved. Your MacBook decides where to connect.
