Has anybody had this problem before:
I'm trying to create a second OpenVPN client in the client2 config page but having difficulty. I upload the new ovpn file but when I do so the Server IP field briefly changes to the new IP before reverting to the one for client1.
If I then apply this it remains the same as client1 and will not start. Also at this point client1 will not restart if stopped.
I tried SSH into the box and after a bit of digging found that there is no client2 directory being created in
/tmp/etc/openvpn and if I cat the files in the client1 directory I can see that the ca.crt cert file is now the one from the file I attempted to use for client2 but the server IP in the config.ovpn file is still client1! Timestamps on the files change to when I hit apply etc.
Router is an Asus RT-AC3200 running 380.65_4
Any help would be most appreciated.
