Problems flashing RT-AC87U_378.53_alpha2.trx on my router
mrdude
Hi Merlin users, I have just built - RT-AC87U_378.53_alpha2.trx from source 3 times now, even wiped my files and started from from the merlin github.
The image builds successfully - but when I try and flash I get this error:
Firmware upgrade unsuccessful. This may result from incorrect image or error transmission. Please check the version of firmware and try again.
I've not had this error before one previous builds- obviously I'm using an RTAC87U router.
Thanks.
EDIT: IGNORE ABOVE
I was able to flash it using Asus firmware restoration utility, I am using optware so I removed my USB drive, I don't know if that had anything to do with the above, but I'm on 3.78.53 alpha 2 now - so all is good.
The version I have is a custom build with oscam built in m8 - it open 2 ports on the router and installs oscam to jffs partition - if you enable custom scripts in jffs. If you still want it ill post it, You can remove those scripts from jffs to stop that happening if you want.
Hello, Can you send me the firmware 378.53 try it
E-mail: shaobing1992@163.com. Thank you
Here you go, I have removed oscam from this build: ASUS RT AC87U 0nly.
https://mega.co.nz/#!tgwhjZDJ!THbUw9BCp6Qd3AS3yz1oqNrBNQ3MIRh3om1RyuA7Nx8
Enjoy
