dCrypt
I have a setup with Movistar fiber connection. My router (Mitrastar) is setup in "semi-bridge" for managing "triple VLAN" scheme for Movistar. Behind it, the Asus AC88U main router is managing the wifi connections and LAN network. Upstream, I have another router as an AiMesh node for extending the LAN to the second floor. Behind it, I have the IPTV decoder.
Everything works perfectly but the IPTV decoder, if it is connected to the AiMesh node.
- If I connect the decoder downstairs, direct connection to the Mitrastar fiber router/gateway, it works.
- If I connect the decoder downstairs, direct connection to the Asus main router, it works.
- If I connect the decoder upstairs, using the cable normally used by the WAN connector in the AiMesh node, it works
- But if I connect the decoder upstairs, plugging it to the AiMesh node, it doesn't work
- I have tried resetting the AiMesh node and setting it up again, but it fails
- I have tried setting up the AiMesh node as an Access Point and it works!! (but this is not what I want)
I am pretty sure it was working before, months ago. Something may have changed after an update.
Any hint?
Thanks a lot
Any hint?
Thanks a lot
