Problems with openvpn client router with different subnet, no internet for lan
carlos
Hi there, i seem to be having problems with setting up openvpn on my tomatousb router.
Not sure why, but the router is able to get internet access but anything connected to the router can't. All devices only connect to the vpn server's public ip's and urls. Dns seems to work fine.
I'd like all or select machines connected to my router to be able to connect to external vpn and use it as the gateway.
My local network has a different subnet than vpn server.
router runs on 192.168.1.0 range
vpn tunnel runs on 10.0.0.0 range
Once vpn link is established, on a machine connected to my home router (the vpn client) i can ping 10.0.0.1 and i can connect to all the ips on the vpn server's eth0 but i can't ping anything outside.
From router i can access and ping internet fine.
i've tried adding nat:
iptables -t nat -I POSTROUTING -s 192.168.1.0/24 -o tun11 -j MASQUERADE
but seems to do nothing..
Checked the table ( iptables -n -L -v -t nat)
Chain PREROUTING (policy ACCEPT 216 packets, 11025 bytes)
pkts bytes target prot opt in out source destination
45 11925 DROP all -- vlan2 * 0.0.0.0/0 192.168.1.0/24
0 0 WANPREROUTING all -- * * 0.0.0.0/0 192.168.1.3
0 0 upnp all -- * * 0.0.0.0/0 192.168.1.3
Chain POSTROUTING (policy ACCEPT 5 packets, 1675 bytes)
27 1468 MASQUERADE all -- * tun11 192.168.1.0/24 0.0.0.0/0
547 30053 MASQUERADE all -- * vlan2 0.0.0.0/0 0.0.0.0/0
1 40 SNAT all -- * br0 192.168.1.0/24 192.168.1.0/24 to:192.168.1.1
Chain OUTPUT (policy ACCEPT 5 packets, 1675 bytes)
Chain WANPREROUTING (1 references)
0 0 DNAT icmp -- * * 0.0.0.0/0 0.0.0.0/0 to:192.168.1.1
Chain upnp (1 references)
Router routing table:
Destination Gateway Genmask Flags Metric Ref Use Iface
10.0.0.5 * 255.255.255.255 UH 0 0 0 tun11
XX.XX.XX.202 192.168.1.2 255.255.255.255 UGH 0 0 0 vlan2
192.168.1.2 * 255.255.255.255 UH 0 0 0 vlan2
10.0.0.0 10.0.0.5 255.255.255.0 UG 0 0 0 tun11
192.168.1.0 * 255.255.255.0 U 0 0 0 br0
192.168.1.0 * 255.255.255.0 U 0 0 0 vlan2
127.0.0.0 * 255.0.0.0 U 0 0 0 lo
default 10.0.0.5 128.0.0.0 UG 0 0 0 tun11
128.0.0.0 10.0.0.5 128.0.0.0 UG 0 0 0 tun11
default 192.168.1.2 0.0.0.0 UG 0 0 0 vlan2
On vpn server:
Nat:
Chain PREROUTING (policy ACCEPT 2317 packets, 124K bytes)
Chain POSTROUTING (policy ACCEPT 336 packets, 24591 bytes)
439 29810 eth0_masq all -- * eth0 0.0.0.0/0 0.0.0.0/0
Chain OUTPUT (policy ACCEPT 336 packets, 24591 bytes)
Chain eth0_masq (1 references)
138 7545 MASQUERADE all -- * * 10.0.0.0/24 0.0.0.0/0
Routes on server:
10.0.0.2 * 255.255.255.255 UH 0 0 0 tun0
XX.XX.XX.200 * 255.255.255.248 U 0 0 0 eth0
10.0.0.0 10.0.0.2 255.255.255.0 UG 0 0 0 tun0
default m201.intermanic 0.0.0.0 UG 0 0 0 eth0
Openvpn config on server side:
rport 3009
lport 4009
proto udp
dev tun
ca /etc/openvpn/easy-rsa/keys/ca.crt
cert /etc/openvpn/easy-rsa/keys/server.crt
key /etc/openvpn/easy-rsa/keys/server.key
dh /etc/openvpn/easy-rsa/keys/dh1024.pem
server 10.0.0.0 255.255.255.0
push "route 10.0.0.0 255.255.255.0"
#tls-auth /etc/openvpn/ta.key 0
#ifconfig-pool-persist ipp.txt
keepalive 10 120
push "redirect-gateway def1"
comp-lzo no
user nobody
group users
persist-key
persist-tun
cipher AES-256-CBC
status openvpn-status.log
verb 5
client-to-client
And config on client side:
# Automatically generated configuration
#daemon
client
dev tun11
proto udp
remote XX.XX.XX.202 4009
lport 3009
resolv-retry 30
persist-key
persist-tun
comp-lzo no
cipher AES-256-CBC
verb 3
ca ca.crt
cert client.crt
key client.key
status-version 2
status status
# Custom Configuration
#script-security 2
#(iptables stuff) up /jffs/openvpn/postup.sh
Also have ip v4 forwarding on both enabled.
Really don't know what's up on why it just won't work. Any help would be apreaciated. Been trying for a lil while but i don't know what to do next to be honest.
